Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
4 Comments:
there could be several reasons to why it doesn't charge but the most common are bad batteries, water damage, broken charging port. all three of these are recommended techs only to fix so i'd take it to my local repair agent and get them to have a look. good luck
by Hortman
Peppe, what do you mean by this "with the connector does not happen charging"?
by oldturkey03
The USB port is ok
He did not take water
by Peppe
the battery if the load with bench power supply accepts the charge
the problem is that you do not see the charging status
by Peppe
