Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
iPhone not charging on power?
Hello ,
I have Iphone 4 , the problem is in that when i connect the charger with , it keeps draining the battery ( on connecting charger battery drains) I check that the battery is ok..and charger also because i have another iphone 4 so...I check it by this. On My another Iphone battery is charging and charger is working.
please tell me the solution of this.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Have you tried charging it while the iPhone is turned off? (Plug in first then turn off phone)
Anyway, you most likely have to change the charger port to fix this problem.
Additionally you can check if iTunes application on a computer recognises the phone.
You can get the charging dock connector replacement from here: iPhone 4 Dock Connector (GSM/AT&T)
Guide on how to replace it: iPhone 4 Dock Connector Replacement
You can also try another battery as well as I have seen a faulty battery cause this issue as well.
Where to get an iFixit Replacement Battery with guide:
iPhone 4 Replacement Battery
iPhone 4 Battery Replacement
iPhone 4 Replacement Battery Image
iPhone 4 Dock Connector (GSM/AT&T) Image
iPhone 4 Battery Image
Guide
Difficulty: Moderate5 - 30 minutes
iPhone 4 Dock Connector Image
Guide
Difficulty: Difficult45 minutes - 1 hour
Score 1
Comments:
sir..
I did all the things..
I replaced the charging dock connector but still the same problem
the iphone is recognised by the Itunes and even i also format and restore it but nothing happen.
Its discharging
by
Hello @yg2607 did you try simply replacing the battery itself?
Cell phone batteries have a lifetime of two to three years or about 300-500 charging cycles. After this, they will need to be replaced.
by
I replace the battery also...still same problem
by
Add a comment
Add your answer
Yash Gambhir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 52
