F H, error code at startup?
F H error code? Whats it mean? Washer stops.
vsouki2000 FH code (Water Inlet Problem--no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power.Check the following:
open water faucets completely
check the screens at inlet hose connection to washer to make sure they are not clogged. Make sure that the water hoses are not kinked. Plug in washer or reconnect power. Re-select cycle and press START.
It can also be caused by a bad drain pump motor as well as a failed flow meter. I suggest that you download the service instructions from the bottom of this page and run the diagnostic cycle. Then let us know what you found.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,483
