The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Questions View all
It's not working and recovery adb problem
Hi *
I unlocked my Nexus 5 n root it n install twrp recovery n install cyanogen mod 13 with gapps
Then I opened super su it says update the software I click on update cwm/twrp
After that it shows only google screen I have done hard factory reset.
Nothing is working.
When ever I turn on my phone only text google appeared with an unlock image
I can't apply adb update cm recovery
Add a comment
1 Answer
Chosen Solution
If you are fine with losing the data, you can reflash the os (https://www.google.com/url?sa=t&source=w...) over the bootloader interface. That would remove CyanogenMod and wipe your data, but your phone should run properly on stock Android again. since your bootloader is unlocked, you could also flash just a new custom recovery, for example twrp, and use it to flash a zip containing CyanogenMod, if you have one have one on your phone. The procedure is basically the same, but instead of downloading the system image, you download the custom recovery and run the command "fastboot flash recovery <file path for custom recovery>" to just flash the recovery.
Score 1
Add a comment
Add your answer
Osman Shaik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 184
