Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
350 Questions View all
Can I swap mid 2012 upper case with one from 2011?
Hi!
I have the 2012 15" non-retina Macbook Pro. It still works just fine but the upper case has got some pretty bad dents over time. I have an old Macbook pro 15" non-retina (some 2011 model) with a broken logic board which I've used for spare parts. Is the upper case from my mid-2012 model replaceable with the one from the 2011 model?
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
You should be OK here.
If we look at the part on the IFIXIT store: MacBook Pro 15" Unibody (Early 2011 through Mid 2012) Upper Case we see both early & mid 2011 models used the same case as the mid 2012 model.
Here's the IFIXIT guide to replace the case: MacBook Pro 15" Unibody Mid 2012 Upper Case Replacement to help you in taking your systems apart for the swap out. Good Luck!
MacBook Pro 15" Unibody (Early 2011 through Mid 2012) Upper Case Image
Product
$299.99
Score 2
Add a comment
Add your answer
Thomasgd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 51
