Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
Can I swap mid 2012 upper case with one from 2011?
Hi!
I have the 2012 15" non-retina Macbook Pro. It still works just fine but the upper case has got some pretty bad dents over time. I have an old Macbook pro 15" non-retina (some 2011 model) with a broken logic board which I've used for spare parts. Is the upper case from my mid-2012 model replaceable with the one from the 2011 model?
Add a comment
1 Answer
Chosen Solution
You should be OK here.
If we look at the part on the IFIXIT store: MacBook Pro 15" Unibody (Early 2011 through Mid 2012) Upper Case we see both early & mid 2011 models used the same case as the mid 2012 model.
Here's the IFIXIT guide to replace the case: MacBook Pro 15" Unibody Mid 2012 Upper Case Replacement to help you in taking your systems apart for the swap out. Good Luck!
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case Image
Product
$299.99
Score 2
Add a comment
Add your answer
Thomasgd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 122
