Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Touch Screen Dead Spots and LCD dim
My son dropped his phone in water and grabbed it right out. We set it to dry and it mostly works. The problem is some spots on the touch screen are unresponsive and the brightness of the screen is really dim until he is on it for awhile and the brightness comes back.
What do I need to replace???
Add a comment
Hi,
First thing to change is the screen. You might have some damage on the motherboard, we could only help you with very HQ close-up pictures.
Add a comment
You should only need to replace the display assembly. Its a pretty cheap and easy fix on a 5S.
While you have the phone open, I would take a look at the battery, battery connector and any of the board you can see. Clean up whatever corrosion you see and inspect the battery for damage. If it was a quick drop, you might be ok.
If you still have issues after you replace the screen, then it will be time for some board level stuff. Especially watch out for quick draining battery, phone heating, etc.
Add a comment
Please click the link and watch then just tell him about your phone problem you may get a good solutions https://youtu.be/J_pcWczZik4
Add a comment
Add your answer
SDC will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 473
