The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
196 Questions View all
Will not power up.
Computer will not power up. Power light flashes 3 times then lights steady, then flashes 3 times again. From what I've read, this indicates incompatible ram installed. Swapping ram chips seemed to fix the problem, but after powering down and trying to power up again, the same problem appeared. Could this be a logic board issue?
Score -1
1 Comment
When this problem began, I hadn't done a thing to the computer. I didn't install new ram until after the problem occurred. It had been working fine for years up until that point. Any ideas or suggestions?
by
Add a comment
1 Answer
Most Helpful Answer
This is a RAM issue. The RAM has to be installed in the correct slots in pairs. Here's the PDF on how to install it: manuals.info.apple.com/en/memory.pdf
Here's a link explaining which slots must be filled first and the type of RAM to use: http://support.apple.com/kb/ht2248?viewl...
Score 1
1 Comment:
If it was working before one of the sticks may have failed or one of the slots. Hopefully you have four sticks. Try one pair at at a time.
by
Add a comment
Add your answer
David Kinsman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,157
