no LCD backlight after digitizer replacement
Hi everyone,
I replaced the digitizer on my daughter's iPad mini and when testing before gluing the glass back down the LCD stays dark. I can see the shapes and words on the screen if I shine a light on it, but there is no backlight. I have checked the backlight fuse/filter/diode and it looks fine, not burned and no point of solder in the center. I'm too nervous to test it with a multimeter lest I make things worse by causing more damage and the pins on mine are really too big anyway. I have also, to the best of my abilities, checked that the LCD connector and port both have no dirt, etc. and look to be in good shape. What else can I check? I'd really like to avoid having to buy another LCD and, if it comes to it, I want to be sure that the LCD is really the issue before I waste the money. Thanks for any help in advance,
Mike
1 Comment
I did remove the LCD before removing the battery because I was unaware of the issue there. I guess I'll need to take it to someone to be tested/fixed. Thanks for the comments.
by Mike
