Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1232 Questions View all
Replaced Battery and Now bottom half of phone Doesn't Work.
I just replace my battery in my iphone 5c and now the Home Button, Speakers, Charging port and have noticed it does not vibrate anymore either. All cables are connected not sure what i did wrong.
Add a comment
Chosen Solution
Sounds like partially ripped volume button cable and charging port ribbon cable assembly.
Charging port assembly connects to charging port, home button and loudspeaker including bottom microphone and earphone jack.
Kind of boggles me how people break charging flex when replacing battery or screen.
Score 1
Add a comment
You need to take the battery out and check when you removed the old battery off the adesive and where did you put the spugger to force the old battery off and you could have caught the flex cable as the vibrator on a 5c is at the top and that flex go,s to the volume and to power and vibrator silent switch and its common to catch the flex that is under the battery and if you have problems with the bottom of the iphone then you really need to take all the screws out and check that the flex cable under the loud speaker to the charging port, also was this water damage,?good luck
2 Comments:
No wasn't water damaged just battery was dying quickly and the phone is at least two years old, bought it refurbished. Thanks I'll take a look
by
You will need a new battery if it’s dying that fast,?good luck
by
Add a comment
Add your answer
Nicholas Spina will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 91
