Laptops manufactured by Toshiba.
950 Questions View all
My Toshiba laptop powers up, but the screen is black.
My laptop powers up, but the screen is black.
Score 253
Comments:
It works for me but it won't stay for long powered on... It blacks out again :/
Any suggestions??
by
MY SON'S SUGGESTION...IT WORKED FOR ME!....Try taking out the battery and putting it back in. Then press shift, F8, and the power button at the same time
by
Thank you so much!!! I'm going to pass this on to everyone I know. I don't know what caused it to do this in the first place. I'm just happy it worked and I didn't spend hours taking it apart and fixing it
by
The battery thing did not work for me.
by
Taking the battery out/f8/shift/power worked for me today! Thank you!!!!!!!
by
Show 218 more comments
Add a comment
Chosen Solution
Hook up an external monitor to determine if you have a motherboard or LCD problem. If the external monitor works, the trouble is with the display or its cables. You should also confirm that your memory is properly installed, and you may want to replace your BIOS battery. I have included a link to disassembly instructions for your unit. Good luck.
http://www.irisvista.com/tech/laptops/to...
Score 35
Comments:
+ good
by
It worked thank u
by
it worked yepi yepi :) :) :)
by
IT WORKED FOR ME TOO! (pressing shift, F8, and the power button at the same time). But WHY did it happen in the first place????!
by
what if sir dont work to external monitor?
by
Show 44 more comments
Add a comment
Most Helpful Answer
The "black screen of death" is usually very easy to repair on a laptop. First, turn your computer off by pressing and holding down the start button. Next, unplug the computer and remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. Getting no results usually indicates a bad motherboard. I hope this helps.
Score 69
Comments:
Wow, worked like a charm! I can get my assignment turned in!!!!
by
Thank you !!!! Fixed it on the first try :D
by
I have a Toshiba laptop that was powering up, but the screen would not turn on. this method fixed the problem on the first try!
by
it worked!.. thank you dude...
by
Add my thanks to the above!! Took only one time!! Sure is great to get such terrific assistance online!!
by
Show 105 more comments
Add a comment
i think i can give you some tips about this -
1- just remove the battery and turn off the charge and laptop .
2-rest for 2 min and than plug the power(Battery) back to laptop
3. press the power key and hold it for like 1 min and restart the computer
if this does not work try restarting the computer in safe mode
1- just restart the computer and press f8 and select safe mode and once you are in computer try updating windows and graphic driver and remove some of start up programs which might can create issues for any other help visit blog Toshiba laptop black screen and boot problem related help and let me know if anyone gets more issue in computer . i will be glad to help
Score 28
Comments:
thanks it was helpful . i fixed my friends laptop . thanks a ton
by
great i got it fixed . worked like charm
by
Thanks that worked
by
Well I've tried several of these remedies listed here with no avail. So now what?
I make my living from my phone and laptop... I show people how to get paid to share apps and games. Please help!
by
Add a comment
For those of you with a laptop that does not have a removable battery, this might help. Hold down the power button to shut off the computer, but DON'T TAKE YOUR FINGER OFF THE POWER BUTTON. Hold it there for about 60 seconds more, and then remove your finger. Then, press the power button again to turn the computer on. I did this, and it worked for me :)
Score 17
Comments:
effectively: what other people have said...
by
Thank you so much, it worked for my, Toshiba Satellite L50-A.
by
This worked. Thank you.
by
I worked!!!
Thank you sooo much.
by
It dide t work now is just blowibg air
by
Show 22 more comments
Add a comment
see comment No beeps, no post just Black Screen
Score 5
Comments:
the one by oldturkey above worked for me! :)
by
Did a lot of searching, and by crikey oldturkey's one worked for me too just now. Seems bizarre, almost like voodoo, but this seemed like the easiest solution from all the other ones I found to try.
Note: my wife pulled the battery out and it still didn't work, but I followed those instructions exactly and it's perfect now first time!
by
I thought it might be over for my laptop but I tried what oldturkey03 suggested and it worked on my first attempt. If you still check this post, thanks a bunch oldturkey03.
Monkies4kids
by
oldturkey03's method worked perfect for me. However, the windows seems to have a problem loading up, the system probably fell. Installed a new copy and is working fine now, thank you.
by
I did as above old turkey o3, worked first time, I had been working on my daughters toshiba for a few hours went away , came back and blank screen. Even after forcing shut down still nothing. I thought a trip to the computer shop was in order!! But thought I'd google the problem and was directed to here and the rest is history back up and running so so easy thank you old turkey03
by
Show 13 more comments
Add a comment
I have a small electronics repair shop out of my home and just yesterday checked in a third Toshiba machine with this same problem: failed GPU. Cause: overheating.
Each owner has said the same thing: over the past few months, every once in a while the screen stayed black during boot-up, but a restart or something similar like removing the battery, letting it sit overnight, or power-cycling made it boot correctly. Eventually nothing would help and they brought their laptops in for repair.
On the first machine I had to troubleshoot for quite a while before determining the issue, including everything mentioned here in this thread, until finally deciding to replace the mobo over re-soldering the GPU (which I incorrectly assumed was my only option). On the second unit I reflowed using a hairdryer, followed by my kitchen oven. Big job. Didn't want to have to do that with this machine, so I'm borrowing a heat gun tomorrow and using this procedure found on YouTube:
https://www.youtube.com/watch?v=cP2QOXNM...
(Warning: rated PG due to mild cursing)
This is a known issue with the laptops in this line and while one of the other suggestions might work and solve your specific problem, be on the watch for the graphics to eventually die due to dust and/or heat buildup in the future. It's HIGHLY recommended to use a cooling pad under these systems (some of the Toshiba User Manuals even go so far as to tell you that you NEED to use one rather than just SUGGEST it.) and to periodically tear-down and clean out the inside around the heatsink, fan, etc. You'll find the dustier or dirtier your normal environment, the more often you'll need to do it---at least twice per year is a good start, especially if you own pets that shed.
If you would like a copy of my t-shoot list to rule out all the other possible problems that can cause the black screen of doom, message me and I'll be glad to share it. Otherwise, assume your machine needs the gpu reflowed and don't trash it!
The hard disk, OS, screen, etc. are all still fine and in working order (unless you've inadvertently pressed the appropriate keys and don't something to the bios or something weird like that.)
IMO, Toshibas are good machines. I still have my original with Windows 95 on it! I own several models and have found, with the proper maintenance, that they'll last well past 10 years. (Believe it or not, I've found that Dells and Acers are the next best performers among abusive users. LOL.) Every manufacturer has weaknesses: none are perfect. Don't expect to not have issues with electronics because you'll always end up disappointed. Heat, dust and mishandling are the three biggest killers.
Good luck - I hope this helps some of you.
Mary
~Psalm 103~
Score 3
Comments:
I have been told that you should shut the screen or else it won't work... IS THAT CORRECT... HELLLPPPPPPP.... my laptop sits down after every 5 mins when I'm not playing so how am I supposed to leave it on? Plz help I'm desperate
by
Thanks for information For more info click on http://goo.gl/M1UCTc
by
Exactly, The same thing happening. The Toshiba Skullcandy are mostly affected. The GPU is dyeing after a certain time. I have seen many in these days. Everything else will work but you wont get a display. And also others stated in previous comments there is no BIOS/CMOS battery in these models, at least the Satellite L50-C models. It is difficult sometimes to determine what is causing the issue. Believe me and Mary as describing in the post an end user can not do much more in this situation. Thanks for your post Mary much appreciated the time to point the common fault in these machines.
by
Add a comment
I also have this type of problem where power on the screen is blank or black.
What I did was to press Fn (Function key) and F5 at the same time. After pressing it for some times my laptop boot.
It works for me.
Try it and give feedback.
K49 AMBO
Score 2
Comments:
it helps!! thank you so much!! now all I got to do is make sure this won't happen again!! thank you again!
by
Stupid question what is a Function key
by
I got my laptop back 3rd time round. 1. was screen 2nd was motherboard 3rd was Harddrive. After putting everything back into Toshiba Laptop everything seemed fine until I switched it off. Later when restarting keyboard lit up but screen black. I tried all the methods above until FN F5 idea and it came to life. 1 thing is for certain...Toshiba Satellite is a dud or I was unlucky to get that 1 oddball that just gives problems. mustve been the laptop that was last job on a Friday knockoff. cheers K49 AMBO.
by
nothing worked for me. Only time i get it to work is to remove heatsink replace paste and heat with hair drier before i put it back together. Works for a while then i turn it off and when i come back t turn it on it is blank screen but making noise as if working.
by
..been doing the F8 routine at start up and everything worked fine, however, in the last couple weeks I've noticed a flickering that occurs which is sometimes a precursor to the screen blacking out.
by
Add a comment
Method : 1
a. Unplug the power
b. Remove the Battery
c. Press and Hold the Power Button for 1 minute
d. Refix the battery & Power
e. Now Switch on ur laptop it will work
[ If the Above Method is not Worked pl. follow my method 2 ]
Method : 2
a. Go to Google Search
b. Download the youtube how to disassemble ur laptop model
[ Ex:- How to disassemble Hp Pavillion Dv6000 youtube ]
c. Watch the Youtube carefully & Disassembly ur laptop
d. Remove the Processor , Ram , Cmos Battery & Clean the Fan
e. Wait for atleast 12 hrs [ i Fixed after 24 hrs]
f. Now Refix all & reassemble ur Laptop
g. Switch on ur Laptop [ 100% it will work ]
Gud Luck..! After u succeeded Comment me
Score 2
Comments:
Hi have a nice Day..!
it seems 100% RAM . so pl check ur RAM / test with new RAM.
Good Luck ..!
by
Can it work for all types of laptop or just toshiba?
by
Add a comment
Something funny - my own very very dim screen problem problem turned out to be Toshiba's eco setting which set brightness to 1. I had accidentally pressed a button that switches it on. The display is so dim it looks off, unless you shine a flashlight on it. Connecting to external display and undoing the eco setting solved it.
This was post Windows 10 though, I'm posting it here in case it helps someone.
Score 1
Comments:
how to increase eco setting brightness in toshiba satellite l55-a5226 laptop
?i am also persuing with same problem.
by
Add a comment
If battery removal doesn't work, change your RAM. Low ram makes computer slow and eventually creates black screen.
Score 1
Add a comment
The problem is much more simple in my case after long time boot with black screen in windows 10 toshiba satellite: problem is with graphic card driver, usually after install windows graphic card driver is allready there, in my case amd radeon hd, but windows ask you on install to dual monitors graphic card, all of us maybe check yes. In Device Manager I disabled in Display Adapters this Dual Monitors adapter, remaining only simple amd driver and display boot on restart very fast. Check your graphic device!
Comments:
I just my Toshiba Laptop which was "Black Screen" (NOT DISPLAYING) working again by following the steps
*Turning off the Laptop
*Unplug the power or Charger
*Remove the battery
*Plug in the charger, Turn it on again then Shut it Down by pressing the Start key + power button
*Release them and Hold down the power for 60 sec
*Turn it on again
by
Add a comment
The monitor and keyboard on my 4 year old Toshiba Qosmio X75 Laptop would not turn on.
Here are a few things that I tried...
1. Press the F4 button (or FN+F4 keys simultaneously) to switch to external monitor and then again to switch back to the laptop monitor.
2. Press the Window key and the P key simultaneously, as per the manual's troubleshooting suggestion.
3. Unplug the power cord, remove the battery, plug in the power cord, press and hold the SHIFT/F8/Power buttons simultaneously (a quick press during the first attempt and then I held them for over a minute on the second attempt).
4. Press and hold the power button for more than a minute.
5. Remove the cover on the bottom of the laptop, remove the RAM memory cards, and put them back in to make sure they are seated properly.
This one fixed the problem...
6. Replace the CMOS battery (a CR2032 coin cell lithium battery). After four years of use, the old one was completely dead.
Hope this helps!
Add a comment
Kris Patel, Your idea worked for me, thanks soooooooooooo much.
Add a comment
Part of screen of my laptop toshiba satellite gets black but when connected to monitor this black part didn't appaer what would be the reason?
Add a comment
I was going off this refrence. It was perfect. Only i had to hit F12 and put it in safe command. And this is one thing that I did difrent. Keept going to black screen.
Add a comment
Add your answer
Janet will be eternally grateful.
Past 24 Hours: 294
Past 7 Days: 2,026
Past 30 Days: 8,469
All Time: 1,139,140
