Why is new Heating Element not Working?
Outlet Thermistor tests ok. Thermal Fuse tests ok. New (tested ok) heating element will not heat up.
Comments:
Chat or phone welcome.
by
Add a comment
1 Answer
Chosen Solution
The heating element warms the air before it enters the dryer drum. Over time, the heating element can burn out, causing the dryer not to heat. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Heating Element for your Dryer
Heating Element - Part # 525502 Mfg Part # WP3387747
RepairClinic Item #525502
Dryer heating element assembly. If the dryer does not heat the thermal fuse should be checked before replacing the heating element. Normally, the element will have a break in the coil if defective.
$45.17
http://www.repairclinic.com/RepairHelp/H...
Score 2
Add a comment
Add your answer
Harold Passonno will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 60
All Time: 362
