Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3217 Questions View all
Why does iPhone 5 charge to 100% then not work when disconnected?
I suspect the battery, but not sure. It will charge to 100%, but then when disconnected it almost immediately stops working. Erratic. When left overnight without charging, it may or may not have charge remaining. Or, when left unplugged would not work until plugged in, at which point it might show 100% or 40% or whatever.
Also, could signal strength be part of the problem? Severe problem occurs in relatively remote locations or in airplane.
Add a comment
Chosen Solution
this is usually signs of a bad battery. it refuses to hold a charge. i would recommend to replace it. The battery run about 20 bucks on amazon and about 10-15 bucks on ebay. When removing the battery be careful with not damaging any other parts of the phone as there are some cables laying under it. i would recommend to watch this video for the full walk through. How to replace your iPhone 5 battery
Score 2
Comments:
Possibly. A lower signal strength means that the phone has to work harder to receive data from the source of the signal. In this case it would be the radio towers if I'm correct.
by
I do agree about what Candido said.
by
Add a comment
The battery can cause so much problems and thats the 1st thing i check,??
Score 2
Comments:
Thanks, Coco, I went ahead with battery, I confirm your suggestion.
by
My pleasure hope you sort it out
Cheers
by
Add a comment
Add your answer
John Lozier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 89
