This TV wont power on.
Set will not power on, i get only two blinking red lights . No sound or video coming from set.
Update (08/24/2016)
I am unable to post a photo of the PSU. However, Visual inspection shows no swollen and/ or leaking Caps.
The standby voltage reads 3.3 v dc a the standby pin. Thank you tremendously for your help!
Update (08/24/2016)
NSX40GT1 psu from my TV
Score 1
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Most Helpful Answer
Ooo Oooo the 2 blink code indicates an over-current condition at the psu outputower supply board's outputs. Possible cause is a connection to either a failed board or (and most commonly) a fault of the PSU itself. Could be as simple as a failed capacitor. Check for any leaking or domed cap. Post some images of the power board with your question. Use this guide for that. That will allow us to see what you see.
Reference Number 201 is the PSU board
Score 2
Add a comment
Add your answer
Ooo Oooo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 115
