This Power Mac G4 has Mirrored Drive Doors.
97 Questions View all
installing 10.5 on MDD!
the machine does not like it, and keeps failing on installing. It is supposed the be able to take it.
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
1 Answer
Chosen Solution
I run Leopard on my MDD and it works great. Do you have more than a minimum level of ram? I have 2 GB in my MDD -- the 1 GHZ processor and the 80GB hard drive. Loaded properly and runs without problem.
I would make sure I had at least 512 MB of ram--1 GB would be better and would format the drive and do a clean install. It should work--Mactracker shows our computers will run 10.5.8. Good luck. Ralph
Score 3
Comments:
+ 10.5.8 runs fine on mine too. dual 1.42 2GB RAM four hard drives 2 DVD burners
by
Now I have disconnected the second DVD drive the machine is behaving better. Could it have been a conflict?
by
Yes, the Optical drives are just like the hard drives, you have to have a master- slave relationship with two units on the same bus.
by
finally got it loaded
had to load 10.4 then 10.5 and that did it
thanks all
by
Add a comment
Add your answer
peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,396
