This Power Mac G4 has Mirrored Drive Doors.
94 Questions View all
Going from 133 MHz to 167 MHz
The G4 can deliver the correct power for the bus speed whether it is 133 MHz or 167 MHz, correct?
Its mainly a matter of changing out and keeping consistent the logicboard, CPU, and RAM so they all have the same bus speed, correct?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
The CPU's bus speed is either 133Mhz, or 167Mhz depending on the motherboard/CPU combo. The RAM will always run at the same speed as the CPU bus, If it cannot (If you are using a CPU that will make the bus speed 167Mhz, and your RAM is limited to 133Mhz [Which it shouldn't normaly be since it is DDR memory] the computer will give you a no ram error)
Score 2
Add a comment
Add your answer
R Michael Olexo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,032
