Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3624 Questions View all
Charging symbol is there but won't increase and sometimes decreases
My phone is plugged in and has the charging symbol but the percentage won't increase and sometimes decreases. I have tried using a different charger but it has no effect. I've left my phone on charge overnight but it stayed the same percentage as before I went to bed. Sometimes I see the percentage jump around (eg. From 26% to 20%) even when it is on charge. Once I noticed it was in the 20%s and ten minutes later was on 1%, all while being plugged in. I've had the phone for 1.5 years and it has never been serviced. Should I take it in to the apple shop and get a new battery?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Hi, sounds very likely just a bad battery. First swap the battery to rule that out....make sure it's original if possible. Then swap the charging port to rule that out. If those both fail it's most likely your tristar chip on the board. Are you using original or aftermarket chargers?
Add a comment
Hi. Sounds annoying that it won't charge.
Well, first of all, be sure to check that the chargingcable isn't the problem. Buy an original Apple Lightning cable.
Double check, that it isn't the lightning connector, that is broken. It's quite hard to say, so if you where me, i'll fix it myself and get a new one. It's cheap, and nearly easy to fix. I'll give it a shot. Lokk here for a Lightning connector replacement.
Still, if that didn't work, try replacing the battery. But, it sounds like it isn't the battery, that isn't the problem. Lokk here for a battery replacement.
Well, because it's over 1 year old, the warrenty isn't there anymore.
Wish you the best luck, cheers.
iPhone 6 Battery Image
Guide
iPhone 6 Battery Replacement
Difficulty: Moderate15 - 45 minutes
iPhone 6 Lightning Connector Assembly Image
Guide
iPhone 6 Lightning Connector Assembly Replacement
Difficulty: Difficult1 - 2 hours
Add a comment
Add your answer
Summer will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 217
All Time: 533
