How to tell if battery dead or problem with logic board?
My early 2011 Macbook Pro recognizes an attached battery but isn't charging it. Per CoconutBattery:
Current Charge: 0 mAh
Maximum Charge: 3716 mAh
Design Capacity: 6900 mAh (53.9%)
Mfg Date: 2011-02-10
Load Cycles: 89
OS X Battery Status: Poor
Battery Temp: 33.6
Charging with 0.0 Watts
Battery State: Discharging
Before I go buy a new battery, is there anyway I can tell if the logic board is damaged and not supplying the battery with power? It runs on the 85w magsafe adapter alone but at significantly reduced clock speed. I tried a SMC reset. Thanks
Update (08/21/2016)
I noticed that these three orange components appear to have been overheated. There appears to be very minimal corrosion in a couple other places on the port side of the board. Should I try to soak/brush it in alcohol as a first step?
2 Comments
The battery is 50% worn out well with half capacity left it says. I think the battery is still okay to use but just won't last as long as a good one.
Does the magsafe charger show a orange light or a green light? Could be liquid damage issue on the board.
by Ben
I can't get an orange light. I removed the logic board but couldn't observe any obvious liquid damage. I'm wondering if there are any places to test with a multimeter to see if the charging circuit is damaged. Also, the battery may have just sat too long uncharged for the computer to deal with it. In that case, any way to jumpstart it, so to speak?
by Sean
