Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Music doesn't play from speakers
Speakers make Ringer and alerts and sounds but will not play music. Does everything use the same speakers? No sound slider in control center with dock connector checked but one appears when Bluetooth speaker is selected in AirPlay . Headset works with volume slider in control panel. No key click sound. Recorder won't play back sound. Videos won't play sound. Mute and volume buttons indicate they are working.
Score 1
Add a comment
1 Answer
Is it on mute? Check the switch on the side of the iPad.
1 Comment:
I have checked the mute button, it works but I have it in the off position. I have replaced the dock connector and the Headset port, digitalization, reset, restored with iTunes backup and every other thing I could find on the Internet. I'm thinking this is a glitch of some kind or a setting problem or app problem but I'm open to anything that could fix it. There's no warranty. I've reading looking for the answer for about two weeks and ad it open twice so i'ts not a easy thing. Thanks, charles12
by
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 59
