The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3508 Questions View all
Replacement screws, how do I measure them?
Hello guys, this time I am here to know if there is an easy way to measure the screws in a set of replacement screws for iPhone 5s.
Thing is I only need the ones holding the home button bracket (1.4mm #000 phillips); the ones holding the battery connector bracket (1.6mm #000 phillips); the ones holding the front panel assembly cable bracket (1.7, 1.7, 1.3 and 1.2mm #000 phillips); the ones holding the earpiece speaker bracket (4.0 and 2.3mm #000 phillips); and the one securing the back of the display assembly to the LCD plate shield (2.7mm #000 phillips).
So I need to know which one is which.
Any help?
Thanks.
Add a comment
1 Answer
Chosen Solution
@caraneday looks like they have been measured by the total length. The only way to measure them properly is by using a vernier caliper. Not an expensive one time investment....
Score 1
Comments:
@oldturkey03 thanks, I'd thought the same but... how accurately would that be? I mean, there are 1.2 and 1.3mm; and the caliper has an error range, so a 1.2mm might be seen as 1.3mm right? :(
by
Sure it could but that's a bit high for a vernier error rate. If that would happen then all of them would measure longer. It's never easy to get all of it right when we did not have a chance to sort the screws during dismantle or if they get mixed up. Toughest part of that job......
by
@oldturkey03 any brand you suggest? a digital ideally :P
by
Not sure where you are locatesd I'd go with a digital rweadout since that will speed up your work and you do not have to struggle with either metric or imperial
by
@oldturkey03 thank you so much!
by
Add a comment
Add your answer
Carlos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 631
