What is the orange and clear plastic part used for. Can't read
What is the orange and clear plastic part used for . Can't read the writing.
That is for "needle maintenance". Basically, you do the following to clean the needle:
1) power off the machine;
2) fill the clear white part with water;
3) open the handle and insert the cleaning unit into the K-Cup receptacle area (note the arrows should point down);
4) slowly close and open the handle 5 times to clean the needle.
Note, if the handle won't close, don't force it - you probably haven't inserted the cleaning unit properly.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 2,402
gagaduncan you want to post some images of the "orange and clear plastic part" with your question so we can see what you see. Use this guide Adding images to an existing question for that
by oldturkey03
