Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Unable to unscrew 1.2mm and 1.3mm Philips #000 screw.
I have the Philips #000 screwdriver from iFixit.
However, I seem to only be able to unscrew the 1.7mm screws. No luck with the smaller 1.2mm and 1.3mm screws. I am currently at this step.
Is this the expected scenario ?
Thanks in advance :)
Add a comment
1 Answer
Chosen Solution
Have you tried a little bigger driver? I normally use a 00 driver on iPhones.
Score 3
5 Comments:
Dang, I do not own a #00 driver. Will try to obtain one and see if it works.
by
Thanks for the info, I've been using #0 Phillips head on iPhones which is probably not optimal.
by
I got the screws out, used a screwdriver that I borrowed from a friend. Kinda disappointing that the ifixit screwdriver does not work..
by
Yeah sometimes I have to use the german phillips head screw driver that pretty much never gets worn out and works for philips head phone screws that are hard to take out.
by
i am having the same problem. Which screw driver did you get from your friend?
by
Add a comment
Add your answer
Daylen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,595
