Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
Virbate Ringer Button Situation?
I just replaced my back cover, so i pretty much reassembled everything on the new cover. When i started my iphone up everything worked fine, except the vibrate/ringer button. I works but for some reason it wont stay on ringer mode. It also vibrates randomly showing that is is on vibrate mode. PLEASE HELP!!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
you need to strip phone back to ringer switch and check that the small plastic toggle is seated correctly in outer switch. it's a fiddly/tiny toggle to reseat but be patient and hopefully it'll be fine. I put phone on side and switch toggle to down position so switch doesn't fall out while I'm trying to put screws in
Score 1
Add a comment
Add your answer
Dustin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 657
