The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
216 Questions View all
My new digitizer's bottom half of the screen is not registering touch.
My new digitizer's bottom half of the screen is not registering touch. What is wrong? The top works fine. but if I were to input a passcode in landscape for example. I can't touch the 3,6, or 9.
Score 1
Add a comment
Chosen Solution
Edric Chen,
it should be digitizer defective. you may have to replace the digitizer
Score 1
Add a comment
Most Helpful Answer
If you can reseat that digitizer connector by pulling it out and putting it back in, you'd be surprised how many problems that solves. :)
It's worth noting, that if your iPad had any power at time of replacement, erratic behavior can occur. I recommend you hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo, before considering the digitizer defective.
Score 2
Comments:
OP: If you do intend on opening the iPad Air yourself you should have a digitizer ready just in case you crack the glass as it requires heat and a lot of patience in taking the glass off and using the right tools.
by
I have reseated it multiple times to no avail.
by
Add a comment
sounds like a defective digitizer, have you tried possibly a new digitizer or the old one if it didn't have any touch problems
Score 1
Comments:
Just tried the old one. Didnt think of doing that for some reason. That one works so the new one has to be defective.
by
yeah thats what it looks like, see if you can return your defective part or exchange it for a new one, where did you buy the digitizer?
by
Add a comment
Add your answer
Edric Chen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 179
