Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
831 Questions View all
Can I upgrade my logic board to a higher GHz?
Currently my 2.53 GHz logic board has a faulty ram slot. I have cleaned both slots and inserted and removed ram out of the bad one multiple times. Can I upgrade to a better Logic board? If so, what's my best option?
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
First try backing the screws that hold the RAM slot mechanism off a quarter of a turn each and test again. Put a 4 GB in the working slot. The one that's not working will sometimes take a lessor stick.
You may be able to use this one, they are both A1278 boards, but I have not seen it listed as compatible.
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board Image
Product
$249.99
Score 2
Comments:
I appreciate the help. I backed off the RAM slot mechanism screws a quarter turn which worked for 1-2 minutes but then the computer continued to shut down and restart. I will purchase this 2.66 GHz and hope that it works. Thanks
by
Ok, i did work. Try another quarter of a turn.
by
Add a comment
No point really. You could find one on eBay but it is not going to be a big improvement. Can you get the largest sized ram for just 1 slot?
Add a comment
would it be possible to replace the port? someone like luis rossman could possibly replace the port
here is his site:
https://www.rossmanngroup.com/
Add a comment
Add your answer
ethanmccrackenis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
