Fuses & Thermostats replaced . Coil heats, then goes out.
I have changed the thermostats and hi limit fuses 2 times. After reassemble, dryer starts fine. Sometime during the cycle, the heating coil goes out. clothes continue to tumble until timer shuts machine. What could be "blowing" the fuses? tested coil for continuity and it is good.
3 Comments
Also checked exhaust pipe. Seems clear.
by Jordy M
Replaced coil, high-limit fuse and thermostat, and the same thing happened. Coil goes on and in 5 or so minutes, blows the fuse and goes out. Dryer continues to spin but with no heat. Any other ideas??
by Jordy M
@jorden just to recap. You replaced the Heating element, the thermal fuse as well as the cycling thermostat? Any chance you can post the part numbers for those pieces?
by oldturkey03
