The fan has three speed settings, but only the first one works.
GD Midea FT30-7U3 When the speed setting lever is moved from 1, which works, to 2 or3, the fan stops.
=== Update (08/13/2016) ==I tried to remove the bottom plate, which was unsuccessful.
1 Comment:
@ranger7 probably a bad switch or bad resistor in the switch. For that you definitely will have to disassemble the fan. OPost some images with your question so we can see what you see. Use this guide Adding images to an existing question for that.
by
Add a comment
