20", 23", and 30" LCD Display introduced in 2004 discontinued in 2010.
66 Questions View all
My monitor has 3 problems. Are they linked?
1. When I turn off the monitor with the power button, it turns off. But when I try to turn it on again with the power button, it doesn't turn back on. I need to unplug the power from the monitor for it to start again.
2. When I increase the brightness to 75%, the whole screen starts flickering fast. When I go up above 80%, it flickers even faster.
3. When my Mac puts the display to sleep, but I move my mouse to wake it up, the monitor doesn't wake up, and there is a green light flashing once every 3 seconds on the motherboard,
My monitor only turns on when I plug it to the computer for the FIRST time. Even then, it only works 20% of the time when I plug it in. I often have to unplug and replug 5 times before it starts.
Do you know what is causing each of these problems?
Are they all linked?
What components are at fault?
Thanks in advance
Add a comment
1 Answer
Chosen Solution
It may be the power supply or possibly the backlight only.
Score 1
it was indeed the power supply. Thanks for your input
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 58
