What is the recommended upgrade , if any worthwhile?
have an old iMac, (Imac mid 2007 with 2,4 Ghz Intel core 2 duo) .
It will not allow upgrades beyond OSX 10.9.5
What can I do?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
You should be able to upgrade to the current OS X.
http://www.everymac.com/systems/apple/im...
Your limiting factor may be your amount of RAM. Or you may not have the hard drive space. What is it telling you when you try to upgrade?
Standard RAM: 1 GB Maximum RAM: 6 GB*
Details: 1 GB of RAM is installed as a single SO-DIMM module.
*Apple officially supports 4 GB of RAM, but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
Score 2
Comments:
simple, but solved it thanks
by
What solved it?
by
Add a comment
Add your answer
lillelnh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 33
