Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
restore iPhone via itunes if touch ID and home button doesn't work?
hello, i have a iphone 6 plus jailbroken running 9.3.3 but i want to do a restore via itunes but the touch ID and HOME BUTTON doesn't work i use the on screen home button ,i was wondering if i can proceed without getting any error such as error 53?? (i heard about).
2 Comments
ok thank u so that mean i can do a restore without worrying about it then?
by
Yes, on the latest iOS update you do not need to worry about error 53 being an issue. That has been since solved.
by
Add a comment
Chosen Solution
Resetting network settings sometimes fixes touch ID not working if phone hasn't been repaired before.
Score 3
2 Comments:
I recently replaced the screen but transfer the touch id and home button on the new screen but idk if something wrong with the flex cable that connects to the touch id (the back panel) but the home button still dont work i have to use the on screen home button. they said apple fixed the issue with 9.2.1 i was on 9.2.1 at the time and i updated via OTA to 9.3.3 and the update works but am wondering if itunes would work.
by
There are multiple points of failure for the home button functionality. The most common ones are the home button extension cable being damaged and the home button ribbon cable being physically cut.
by
Add a comment
Most Helpful Answer
The error 53 is no longer an issue. Apple resolved the issue about 6 months ago. The error 53 came from the original home button was paired with the motherboard of the phone. If the home button was replaced the home button was no longer paired with the motherboard giving the error 53. If you replaced the home button on this phone you will not have Touch ID (which doesn't matter because you don't have it now) but the home button should work
Score 3
1 Comment:
i need your help
please tell me i have i phone 6 plus but i replace the home key.
please tell me any solution restore by itunes
by
Add a comment
Add your answer
Nickson Musiq will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 871
