The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
282 Questions View all
wont stay on for more then 1 min after unpluge ?
buy axcient i stuck a pin in the head phone pluge . after that my phone dont work . it shuts off in less then a min without being connected to the charger . what can i do to fix it .
Do the headphones work still? Or did you mean you stuck it in the charging port?
Add a comment
Chosen Solution
Sounds like you need to replace the battery, get it here.
Add a comment
Was the pin the first time when you noticed this? Did your battery work well beforehand? Then the pin in the "Headphone jack" shouldn't have done anything to battery life unless you somehow shorted and damaged it?
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 552
