Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
iPhone 3G Power button seems to be broken .
It seems like the power button on my iphone 3g doesnt work, It works time to time randomly if i hold the front and back of the top right corner while pressing the button pretty hard. Is there any solutions to get the phone to go to DFU mode or basically a complete fix to it in general?
Thank you guys in advance!
Score -1
Add a comment
Chosen Solution
try opening phone when powered off and checking connector 5 (has power switch one end, headphone jack, mute, volume at other)
do you have any problems with these functions?
the "flange" on power flex gets less springy with time/use. i'd try replacing that first. It's a tricky/fiddly job, just be patient....
iPhone 3G Headphone Jack Replacement
Add a comment
yes,you can change the power flex also the sensor flex first.
I think it will help you!
Add a comment
Add your answer
Victor Ng will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,026
