My fan is making a lot of noise.
I need to get a new fan for my computer but am having trouble finding one also how do I take the cover off so I can replace the fan?
Score 2
1 Comment
I had a lot of problems opening the computer but did do it and did fix it by just cleaning the fan and oiling it with sewing machine oil I have one screw left over could not work out where it came from.The good thing is it is very quiet now and runs much better.
by
Add a comment
Chosen Solution
Try one of these guides to see if one is similar to your Toshiba. It will help you to get to the fan.
As for finding a fan, try notebookpartsshop.com, eBay or Amazon. I'm sure one is available to purchase.
Also, checkout this forum on loud Toshiba fans.
Score 3
2 Comments:
Thank you I will try to remove fan and give it a drop of oil.
by
Hello ! I have the same probleme, how did you remove the fan ? I dont know how to open the computer to get it.
Thanks a lot
by
Add a comment
If you change to a new fan then it's best to also clean the core of the CPU with some isopropyl alcohol.
Score 1
Add a comment
Add your answer
Peter Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,339
