Why does the window not work on the passenger side?
The passenger side power window will not work with switch on that door or the switch on the drivers side .
There could be a number of reasons the window doesn't work.
The window regulator could be broken (do you hear the sound of the motor but the window doesn't move), the power motor could be done . There could be a broken wire to the motor. (these tend to be in the door hinge area were the wires go from the body to the door). The switch can also cause the same issue . If one switch is bad it can prevent the other from working (usually the drivers switch will be the problem ). Dont waste time with the fuse unless all the windows quit working . Hope this helps
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,231
