Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
406 Questions View all
Can I change the display with early 2013 version?
Hi, I was grabbing my laptop by the screen and it cracked!
I guess it's just getting too old.
I was checking ebay and I saw a 2013 version LCD for about 200e.
Can I replace the screen on a 2011 15" macbook pro with 2013?
If not which display assembly can I replace with I would rather a high resolution one.
I need the complete assembly.
Thanks for the help in advance.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
As to grabbing your system you do need to be more careful as any system grabbed in the wrong way will crack the display or worse!
No, you can't just use any display assembly as Apple changed the interconnections. You'll need either a gloss or anti glare display for your series. Here are your possible choices:
Here is the IFIXIT guide you'll need to follow to replace it: MacBook Pro 15" Unibody Early 2011 Display Replacement.
MacBook Pro 15" Unibody (Early 2011/Late 2011) Display Assembly Image
Score 1
Add a comment
Add your answer
Reza Ghaffarian Shirazi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
