The Asus Transformer Book T100TA is a full Windows 8.1 hybrid tablet.
56 Questions View all
Where to buy Wifi Antenna?
Hey guys,
I'm searching for the wifi antenna for the Asus Transformer Book T100TAM-DK001B. I live in Europe so it has to be able to ship to Europe. On te wifi antenna itself stands "T100 MP-TD". Hope that explains more. The struggle was that I disconnected the cable and the freaking socket came with it too. I know I screwed it hah, but I'm searching for the wifi antenna and if possible the socket for the motherboard. The wifi is not bad or whatever it's just dead. I thought it still made connection but probably not. I hope I can repair this cable. If not, is there another way to fix it?
Can you pls upload a pic of it so as to see how bad its gone .. my be we can suggest how gonna fix it back without replacing it
I figured out that the cable is broken on like 2 places, thanks anyway for the idea but it doesn't matters anymore.
Add a comment
1 Answer
Chosen Solution
Found one on eBay, tell me if the Wi-Fi antenna cable and antenna is correct:
I've never managed to repair antenna cables but I have repaired the antenna socket / jack on the logic board.
Basically needs to be resoldered on if possible.
If you can resolder it you will need to make sure that you don't solder it upside down, if you do it wrong there will be no Wi-Fi reception, usually two soldering points on the Wi-Fi plugin.
Score 3
Add a comment
Add your answer
Stijn Helmonds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 95
