How do I remove the processor from a MDD computer?
I want to remove the processor and mother board from my computer so that I can install a new motherboard and processor but I cannot figure out how to release the processor from the board.
Any written instructions or photo help files on this topic would be greatly appreciated, thanks.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
This guide is incomplete but will get you down to the CPUs.: How do I remove the processor from a MDD computer?
Please tell us the specific MDD you have (on a plate on the back of the machine.
Score 2
Comments:
Add a comment
Hello Laurie,
First you need to discharge yourself - touch a metal surface of the MDD with your hand and right after you've done that you can continue safely.
*Edit : Remove the Heatsink*
the yellow box indicates the connector underneath.
1 - in these two ellipses go your thumbs. apply a bit pressure.
2 - index and middle finger go under the board and pull up the board gently. you work against the pressure of your thumbs and the force of the connector. but I find this quite comfortable.
Regards Jan.
Score 1
Add a comment
Add your answer
Laurie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,304
