The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1529 Questions View all
Power button, volume control + vibrate toggle not working
I replaced the battery in my iPhone 5c. Everything seemed to work fine afterwards, until I noticed that the power, volume control and vibrate toggle switch are inoperative now. I rechecked everything I touched inside the phone and everything appears normal and I am using the extra accessibility button to get by, but would like the phone to work properly. Is there a common component with these three buttons that I could have damaged while prying the battery out?
Score 1
Add a comment
1 Answer
Chosen Solution
Yes, there is a flex cable that is right near the top of battery that cant get pinched or cut. This flex cable is one big piece that has the power, volume and silent toggle on it. If this is cut, then youll have to replace it. This would require you to remove the motherboard. iFixit has a great guide though. It's not that hard. It's just a bit tedious.
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
