Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1002 Questions View all
If I change the motherboard on my iPhone6s what will happen?
What will happen if I change the motherboard in my iphone6s?
Score 2
Comments:
Ok I have a similar problem but mines a new phone model I forgot my new email and by it being a new phone I didn’t get chance to remember the number so I cannot unlock it so if I change the motherboard will it fix the problem
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
@omar12708 the logic board is for all intent and purposes the phone. Replacing that board is like a different phone. Not sure what you are planning on, so give us a bit of a hint of what you are up to.
Score 3
Comments:
Well I lost all of my iCloud password and I have no access to my gmail so I can re get it back and the closets phone shop from here is 2 hours away. So if I restore it would basically be a new phone again I will have to put all my information back?
by
Note that restoring it will not remove any apple ID activation lock on the iPhone.
by
So iCloud would stay on it?
by
Yes, if it has been setup to have an activation lock on it.
You can check here: https://www.icloud.com/activationlock/
by
@omar12708 @benjamen50 is correct. IF the replacement logic board has a lock on it you cannot use it. So if you do buy a replacement you have to make sure that it is not locked. If it is not, then you must transfer all your information to your "new" phone. All your data on the "old" phone will be lost since it is stored on the logic board.
by
Add a comment
@oldturkey03 if I have a iPhone 6 that has a password lock on it and I change the logic board will it be factory reset? Like if I bought a brand new iphone
Comments:
@chino351 for as long as that replacement board is not locked etc. yes it will be like a new phone.
by
If you only change the logic board, the Touch ID will not work.
by
@mandy i just would like to confirm, if i let my iPhone 6s be repair or change in motherboard the iPhone will not detect my Touch ID? like i can't use the Touch ID anymore?
by
Add a comment
Add your answer
Omar will be eternally grateful.
Past 24 Hours: 22
Past 7 Days: 95
Past 30 Days: 404
All Time: 1,633
