Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 Questions View all
Why is my screen black after battery replacement?
I replaced the battery on my iPhone 5. The screen is fine when the front and back of the phone are separate. When I go to close the phone up, the image starts to fade. There are also vertical lines while the overall image is fading. It seems to be related to something on the left side of the phone near the top. By the time the phone is closed up, the screen is black. The home button and touchscreen still work even though I can't see anything on the screen. Any ideas?
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Seems that you have bent too mach the front assembly flex cables..
You should never bent them over 45 degrees, also a clue is the vertical lines.
Unfortunately you have to replace your front assembly (lcd), but this time follow
this giude:
iPhone 5 Screen Replacement
Comments:
You are right - when I first lifted the front off, it did bend back too far. I'll look into the cost of replacing the display...might just skip it and get a new phone.
by
Add a comment
Sounds like maybe its seen its better days like mine and its not even a year old. I just posted about my phone a few more mutes ago. Maybe you can do like I did and contact the product company that made your phone and explain to them your problem and see if they can repair it.. Its evadentally not a easy fix so let the experts take over. I wish you better luck with your phone .
Add a comment
Add your answer
Matt Vanhouten will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
