Model A1318 / 32 or 64 GB capacity
386 Questions View all
Replaced digitizer, cleaned logic board with 91% alcohol with q-tip...
Ipod touch 3rd gen water damaged... I replaced digitizer made sure cable was connected, cleaned both sided of the logic board with alcohol. Do I have to clean in between the logic board where the memory is located and underneath the flex cable ends connected to the logic board?
Add a comment
1 Answer
Chosen Solution
I would clean everywhere. And where ever you can get the alcohol to, get it there and try to use contact cleaner and a toothbrush to get rid of any possible corrosion. Make sure you get all the connectors as well.
Score 3
Ok after spraying the logic board with Deoxit and Using Dexoit Gold on all contacts that I could find both top and bottom of board. The touch screen still has no function at all, Dead.
Add a comment
Add your answer
Lawrence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,624
