Many black vertical lines, 1/8" apart across whole screen.
Hello,
My TV has about 200 thin vertical black lines (!3 px across each) running along the length of the screen, perfectly spaced ~1/8" apart. They are clean, not "fuzzy" and are still, they don't move across the screen. In some parts of the screen when a strong color comes on the screen (usually a dark color) they will disappear and show that small portion of the image perfectly, ie: not dead pixels.
As I googled around I have not found anyone else presenting with this issue. It's typically a single or few lines running across, and that ends up being a broken capacitor or poor internal connection by the sounds of it.
Anyone have any ideas?
Thanks for your help!
Comments:
Are the lines in the same place every time you power on and off the TV?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
@karldprice if those are vertical lines than it is most likely the T-con board if they are horizontal than most likely the LCD panel.
Score 1
Comments:
Hi there,
I have this problem too, and I was not able to fix it by changing the T-con board. It is possible that it could be cause by a fault in the main board?
BTW, the lines that I am getting are very thick vertical lines.
Thanks
by
Add a comment
Add your answer
issueseven will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 8
All Time: 138
