Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
454 Questions View all
Where I can buy this black foam?
Hello everybody, I want to ask your help mainly to informatics or electricians. My iMac crashed, and put an apple assistant, their response was that it was the power supply and how the model was discontinued not repaired, the result was this: I got home and turned on the machine and gave a short circuit and then smoke everywhere, open the machine and had disconnected cables and broken plastic, did not complain because I was going into the said and not said. Sent come a power source for eBay, only need to buy a foam to put together the power supply, which will have about 15 cm. does anyone know where I can buy this? iMac 24´ midd 2007. thank you so much.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Portuguese: Eu não me preocuparia sobre a substituição do selo de espuma. uma tira de fita eletricistas vai fazer tudo para isolar a parte da estrutura de metal.
English: I wouldn't worry about replacing the foam seal. A strip of electricians tape will do just to isolate the part from the metal frame.
Score 3
Comments:
Thank you Dan for your feedback, very useful. So, I can replace foam for strip of electrians in a plastic near the power supply without problems, right? thanks
by
Sim! (Yes!)
Será que ele derreter? (Did it melt?)
by
Add a comment
Add your answer
Miguel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
