Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1209 Questions View all
Why is the touch screen unresponsive?
I dropped my iPhone 6s and cracked the screen. Brough it to the repair shop to get it replaced. After replacement some of the letter "n" and "j" are unresponsive.
The strangest thing is that quite often the touch starts to do things itself. It goes into apps and opens messages itself.
Is this most likely a faulty digitiser or could it be something else ?
Comments:
And forgot the mention the 3D Touch doesn't work the way it should either.
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Hello,
This looks like a faulty digitizer. I meet this problem before and i fixed it by replacing the lcd assembly with a new one. You should have a warranty on that repair and they should change it with a new one.
Score 2
Comments:
I have the warranty so they will replace it. Is it possible that the 3D Touch isn't functioning correctly because of the fault in the digitiser ?
by
Yes, because the 3d touch is part of the screen. Everything should work fine after they replace it.
by
Great, thanks very much. Was just making sure. Screen was genuine from what I've been told. €150
by
Genuine or not they can still be faulty screens FYI.
by
Add a comment
Add your answer
kamiljcool will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 139
