The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1427 Questions View all
How to remove water from LCD backlight?
Hello,
I have a iPhone 5c with water damage, the water is in the backlights, but the LCD and digitizer still work perfectly except for the watermarks in the LCD. How would I remove the watermarks without buying a new LCD assembly?
Comments:
Also, is there any sort of take apart guide for the LCD?
by
If I remember correctly you can carefully take off the black backlight piece + desolder the 3 solder joints on the backlight ribbon connector. Then basically put another one on. I tried cleaning it, the best way is to replace the back black backlight thingy.
Something like this:
http://www.eddogo.com/lcd-backlight-back...
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You certainly could try to fix it, but honestly, anything water related.. I would just replace the front panel assembly. I trust that a lot more than hoping that water didn't slowly start creeping into anywhere on the phone.
The kit isn't too expensive, considering you can always use the tools again. Be aware that "This part does not include the home button, front camera assembly, earpiece speaker, or the LCD shield plate. You will need to transfer these parts from your old display assembly to your new part."
Here is the guide to do the replacement if you so choose to do it.
Good luck and keep us posted!
iPhone 5c LCD Screen and Digitizer Image
Score 1
Add a comment
Add your answer
Gigabit87898 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 61
