G5 does not power on consistantly.
G5 started not turning on consistently four days ago, sometimes would sometimes not. Opened it up, reset SMU, worked once but now not. LED 1 is lit. LED 2 blinks when internal power button is pushed but will not stay on. What do you think new power supply or logic board?
Score -1
Add a comment
1 Answer
Chosen Solution
This power supply problem is so common that I keep two of them in stock. You need Apple part # 661-3625. You will most likely not find a new one only rebuilt or used. Prices vary greatly. I usually pay about $110 for a good one. The are also capacitor kits to rebuild them on eBay and the web for about $18.00.
The trick to removing them easily is to first unscrew them and pull up on on both ends to avoid binding. I use a hemostat on the left screw.
Score 1
1 Comment:
Add a comment
Add your answer
Gerald will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,797
