The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Black screen after minor shock, power button doesn't seem to turn off
Hi All,
Just posting here in one last attempt to get this thing working without buying a new display assembly.
My brother used his phone to playfully hit a friend (who was acting dumb) on the stomach. The amount of force the phone supposedly received was probably about the same as dropping it a couple feet onto a carpeted floor. However, after this incident the LCD stopped working. It still played sounds and the capacitive touch buttons still lit up when pressed.
At first I thought it was the motherboard, since it was a refurb I had just installed to replace one damaged by rain. I sent the refurb back and bought a new one, but the problem persisted.
I've visually inspected the cables as best I can, and they seem to be fine. I don't believe the digitizer is working, since the capacitive touch buttons don't light up when you touch the screen (they're supposed to, right?). Also, when I press the power button it doesn't disable the capacitive touch buttons, which makes me think it's not shutting off (which is why I originally thought it was a motherboard problem).
It seems odd that a light tap, something much less forceful than a drop on a hard surface (even in a case), would have ruined the screen, but maybe it did. Or maybe there was some water that was in the screen and the knock moved it into a critical area.
Anybody have any ideas as to what to try before buying a new display assembly?
Thanks
Add a comment
Chosen Solution
Ended up replacing the screen for $70 and it fixed the problem.
Add a comment
There is a posibility that the screen connector came loose but you're probably going to need a new screen as this is usually caused by the LCD screen being broken.
2 Comments:
Yeah, I've reseated all the connectors already but no luck. Oh well. Went ahead and bought a new screen. This is turning into an expensive phone to maintain...
by
s4's aren't cheap to replace the screen on, good luck
by
Add a comment
Add your answer
Kyle Combes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 125
