Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Can I fix touch ID by replacing the home button shield cable?
Hi,
So I've *successfully* replaced a water damaged screen on my iPhone 6, retaining the original home button, shield plate and home button cables. I now have a functional phone and home button but with no touch ID (yes I have tried a hard reset and re-seating all the connections).
I cannot see any damage, but it was difficult to pry up the original shield cable from the old screen and if any damage occurred I think it was probably there.
The touch ID was still working in the old assembly after the water damage.
I have read varying accounts of whether replacing the long home button shield cable can restore touch ID, or whether this is part of the logic board / home button set that must stay together.
Can anyone clarify? I ask in particular after seeing the iFixit disclaimer for the "iPhone 6 LCD Shield Plate with Sticker and Home Cable" part, stating "Please Note: Replacing the cable will cause the Touch ID sensor to stop working".
Thank you.
1 Comment
If it's basically this then there is no problem replacing it.
iPhone 6 Home Button Link Cable
by
Add a comment
Chosen Solution
No one can verify. We don't have your phone, not even a picture of the damage area. You have to try yourself.
However it is highly likely, since it still works in the old unit.
Score 3
Add a comment
Hey Caitlin Corkhill,
Sadly if you replace the shield with the cable, it will stop the touch ID function.
3 Comments:
No, just replacing the button itself causes this problem
by
He's talking about the cable on the shield, read better Tom and than reply.
by
I don't understand how a home button extension cable replacement would mean touch ID wont work.
by
Add a comment
Add your answer
Caitlin Corkhill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 147
