Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
512 Questions View all
Does it matter which heat gun do I use for screen replacement?
How hot should the heat gun get? Mine is 250ºC.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The heat gun itself is a little less important. You should use an infrared thermometer to know how hot your getting the device that you're working on. Like this
https://www.google.com/search?q=hde+infr...
Score 2
Comments:
Thanks. That's helpful.
by
Add a comment
Most Helpful Answer
Hi,
It doesn't matter really no, how close you get depends how hot the surface will get anyway, so you need to know how to control that really, making it too hot will damage it, if it's not hot enough you'll have a hard time prying anything off. :-)
Score 3
Comments:
But how do I know if it's too hot?
by
What are you trying to achieve? Glass removal or removal of the screen itself?
by
Screen removal.
by
Ok, you need to heat it up so it's a little hot (so you can still touch it, but only for a few seconds) but not too hot that you can't touch it at all, otherwise you risk damaging the OLED screen, this will soften up the adhesive enough for you to get under.
by
Or use a infored thermometer.
The easiest solution is using a hot mat or heat plate, as you can set the actual heat you need.
by
Show 1 more comment
Add a comment
Hey Mikk Rebase,
It doesn't matter which heatgun you use, you need like 900 watt. Thats enough.
Score 2
Add a comment
Add your answer
Mikk Rebase will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 182
All Time: 572
