Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Is it firmware or the actual screen thats the issue (Desperate help)
So, I have a iphone 6 twas working super fine for about a year and 6 months. All of a sudden a few updates happened and things got worse.
1* . The iphone would be super untouch responsive (when I locked screen and unloked I could use the screen for around a few minutes then it would go back to being unresponvie and so fourth).
  • 2. I removed the case from the phone and the screen protector, wiped data and restored backup. (worked for a while like 2-3 days and went back to normal) THE only apps I was using is whatsapp and spotify
  • 3. Fully wiped the phone started using it as new, the phone worked for a week had the minor issue again
  • 4. over time it has gotten worse and now the screen does what it wants with out even touching it. The unresponsive touch does not work ect,
Not sure what the problem is, a guy told me a wire may be corroded but thats strange. As a last resort I might change the screen and see if that works.
notes: No water damage, no damage to the phone (has not been dropped) phones in grade A* condition.
Add a comment
1 Answer
Chosen Solution
Hi,
I would try changing your screen, if this doesn't resolve the issue, then the touch IC has failed and you would need that replacing.
Score 1
Add a comment
Add your answer
French Montana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 43
